I got my rig six months ago, 2005 Wrangler SE 2 Door. I’m curious what should go in this area of the engine bay? I didn’t get the bottle Jack with the TJ, is this where it’s kept? Thanks!
ABS. Cruise control server is a little more aft of that and mounted on or near the fenderSo is that for Cruise Control or ABS? Both?
Though I am installing my compressor there, I see a harness with connector not connected to anything. I am considering adding cruise control and am curious if the connector I see is the factory cruise control harness...
ABS module, Cruise module was mounted on the inner fender behind the washer fluid reservoirSo is that for Cruise Control or ABS? Both?
