Gentlemen,
Thought I would post an update. I replaced the fuel pump and pressure regulator. While I had the tank dropped, I sanded down the tabs on the overflow preventer to provide for smooth movement without sticking, which it was. Engine ran great at start up. Filled the tank, and I’m happy to report, the fuel spillage I have been dealing with for years is gone, thanks to sanding down those tabs! I just turned on the gas handle and let it run. It stopped like it was supposed to! However, the missing of the engine came back when the tank got towards empty. I will be replacing the upstream O2 sensors this weekend, and the downstream ones after I drive the Jeep for a tank or two, to see if the upstreams fix the problem. And yes, I got the NTK sensors! LOL! If I still have issues, I will check the coil pack (again), and replace it (again) if needed. After that, it’s moving to replacing the injectors, I suppose. However, I am always up for suggestions!
