So...I’m not a mechanic but a tinkerer. I replaced the 2.5L engine in my 5spd ‘97 Wrangler with another 2.5 from another jeep.
In the process I didn’t properly label the wires. I ended up connecting the ground from the alternator to the output on the starter. I think I’ve fried a component. The starter would not turn properly but all is right with it now. However, the plugs are not firing now in the new engine. Less than a volt (tested with voltmeter) goes into the distributor cap with the ignition turned to start. The engine turns over fine. No spark on plugs. I will replace the coil in the morning with the one from the original engine. I couldn’t find any blown fuses. Any idea what else or how else to troubleshoot this? The Haynes manual mostly lists Fuel issues but with the plugs out checking for spark I could smell gas in the cylinders.
Any help??
Any help??
