About a month ago I got a 1999 TJ with 66,000 miles on it. This jeep is a right hand drive and is in great condition cosmetically.
Interior was well maintained, frame is undercoated with zero rust.
The gentlemen I got it from told me there was a sputter in the engine but it was still drivable. I have driven the jeep around town cruising 45-55mph and have been on the interstate running 75mph. The jeep sputters/bucks mainly under acceleration but once you get to cruising speed it gets smoother but it's like you can feel the engine sporadically bucking.
No check engine light when I picked it up from the guy either. I did turn the key to the on position to ensure the CEL worked.
Below is a list of things the previous owner did to try and fix:
I read on a forum on here the NTK/NGK supplied OEM O2 sensors so I went with several other NTK/NGK sensors when replacing since I ordered direct from NGK.com.
I will note that after having the battery unhooked to install sensors the jeep seems to run good for the first ride then it goes back to normal again.
There is also no check engine light on. The only time the CEL came on was when I installed the NTK MAP sensor as mentioned above. As soon as I put the original back on and cleared the code it has not come back on since.
I have read several forums on this site before posting. Seems many people on here have a pile of knowledge so hopefully someone can point me in the right direction.
Looking for suggestions on what else to check or try.
- Changed fuel pump
- New plugs, wires, and distributor
- Cut exhaust pipe before the CAT to ensure it wasn't plugged and causing a problem. This has since been patched at a muffler shop.
- New upstream NTK O2 sensor (P/N 23179) - I have tried running with this unplugged as I have seen on some other threads and it does not make a noticeable difference
- New NGK ignition coil (P/N 48633 U1085)
- New NTK TPS (P/N 75426 TH0089)
- New NTK CPS (P/N 73315 EH0249)
- New NTK AIT sensor (P/N 75845 AJ0013)
- New NTK MAP sensor (P/N 74299 MA0114) check engine light came on after this (Code P0107 MAP sensor voltage too low) and it idled awful so I put original back in, cleared code and back to how it was before
- Checked spark between distributor and ignition coil
- Check spark on all spark plugs and check them for sign of oil/burnt but all looked good
- Checked fuel injector wiring with a noid light and all were good
- Cleaned IAC with throttle body cleaned and reinstalled - was not dirty at all to begin with
- Should I take the throttle body off and make sure it is thoroughly cleaned?
- Should I replace the ECM?
- Should I check the timing?
