Hello all,
I have a 2003 TJ 4.0L Manuel Sport. The engine problems started around a year ago when my ECU died, or at least that was my first diagnosis. I got one through Oreilys from a pick and pull and plugged her in and she ran fine. However after the replacement, I had two new codes. P1689 and p1899. The corrective action was to replace the crankshaft sensor and camshaft sensors. The codes didn’t clear but the engine still ran reliably, with the exception that as I take the clutch out, the engine would stall if I didn’t give it some gas.
Fast forward about 9 months and the engine is now stalling on me regardless of give it gas or speed. Found out that the computer was from an automatic engine. So I got a good computer in the mail from a good company that refurbished ECUs. This did not solve my problem how ever. So I took it to a different mechanic, who diagnosed it a a fuel purge valve seizing. Replaced it and said it ran great. After I drove for about 25 mins, the car stalled again as I came to a stop. I now have the P0320 code.
The engine sounds great and starts great if it sits for a while. But after I drive for about 25 mins, it stalls out and won’t start, the engine may turnover slightly, but won’t start up proper unless it sits. Not sure if this is unique but I don’t know what else it could be.
