OK, so this is in reference to my wife's 2011 Jeep Liberty.
I was changing out her rear brakes and rotors yesterday, everything goes fine like normal but when i'm done, and take it for a test drive, upon starting up the vehicle the ESP and ABS lights in the cluster are illuminated and won't shut off.
I tried scouring the internet a bit and some people say if I did not open the bleed valve when compressing the brake piston, it would force something inward that would trigger the sensor.
I have no clue...and there was no info on what the solution was. Any ideas? Suggestions? Did I do something wrong by compressing the piston without opening the bleed valve? Has anyone encountered something like this before and have a solution?
