Exhaust Coatings
Wildman
Staff Member
In the hills of WA
Howdy all,
So I talked about this a little in my build thread and am still looking for options for coating my block hugger headers and the Y pipe. Now before anyone asks I do NOT have a 4.0 I-6 or 2.5 I-4 engine in my TJ. With the amount of folks who are dropping some type of V-8 into their TJ's I figured this would be a good discussion to have. I had a Dodge magnum V-8 5.2 in my Jeep and due to heat it melted plastic parts in the engine compartment. So I added louvers to my hood and was always looking for other under hood cooling ideas.
Just found this stuff and had never heard of them before. Good for the DIY people but am skeptical about how well it would work.
Closest ceramic place to me.
And then of course there is paint like from VHT or Eastwood
While it may not be a issue for stock engine TJ's I KNOW it can be a issue for those of use with swapped in V-8's.
Here is just one example of what I am talking about. So because of things like this I am looking to try to coat my headers and Y pipe somehow to try and lower the heat in the engine compartment.
What has others done? And no I do not want to use header wrap on my headers or exhaust since that holds in the moisture and can lead to rusted out headers or exhaust.
pagrey
TJ Guru
Los Angeles, CA, USA
My opinion is ceramic coatings develop fine cracks and lead to corrosion issues just like power coatings. Fiberglass wraps or header specific wraps might trap water but they insulate much better. At the end of the day both lead to rusted and cracked headers but the wrap provides much more insulation from heat. Long term none of these things work that's why they don't appear on factory vehicles.
Reactions: Wildman
Wildman
Wildman
Staff Member
In the hills of WA
Well which one reduces the heat BEST? I really don't give a hoot about the supposed HP increase I just want to cut down on under hood heat temps.
I've read more people complain about header wraps than ceramic coating but I am not going to argue that they all have their own issues.
Chris
Administrator
Staff Member
Florence, AZ
I’ve had so many things ceramic coated it’s insane. The difference it makes is astounding to say the least.
Reactions: Wildman
Wildman
Wildman
Staff Member
In the hills of WA
This will be the first time I ever try ceramic coating if I go that route. So I have NO idea what any of it is like. Which is why I'm asking here.
pagrey
TJ Guru
Thick fiberglass or header wrap will work better. There is nothing wrong with ceramic but as far as heat transfer thicker is better. It will be easier to keep an eye on ceramic as far as corrosion goes.
Reactions: Wildman
Wildman
Wildman
Staff Member
In the hills of WA
I think I used header wrap ONCE but I didn't own the rig long enough to know how fast the headers rusted out. Or if they even did.
Now I realize part of this is the quality of the product that you are starting with. If you wrap or coat a set of thin walled headers they aren't going to last any where near as long as something with thicker tubed headers.
I guess part of this comes down to which one will cause the item they are protecting/covering/coating to rust faster? From everything I have read and heard it is the wrap. But I can't say this is true.
BuildBreakRepeat
Occasional Genius
McKenzie Bridge, Oregon
I would ceramic coat and then wrap - I bet you get 10 years out of it.
Chris
Administrator
Staff Member
Florence, AZ
It cools things down so much you won’t even believe it. I could touch the headers on my Ducati after racing it for an hour on back roads and they were nothing more than luke warm.
Reactions: toximus and Wildman
toximus
I live in my Jeep
Northern WI
I'm interested too.
While the wrap can absorb water, won't it also dry out quickly due to the heat?
Wildman
Wildman
Staff Member
In the hills of WA
Damn makes me want to take my Harley exhaust in and get it coated also. Isn't as bad as it use to be now since I don't have a right lower leg to feel that heat but it can still get pretty warm.
I'm hoping between doing the headers and Y pipe and then coating the cab in Lizard Skin it will cut the temps when on the trail. My floorboard was so hot that I couldn't put a iced drink in the cup holder as it would melt in 10-15 minutes.
Wildman
Wildman
Staff Member
In the hills of WA
I'm interested too.
I thought you might also be interested in this along with other members who have done engine swaps.
I thought the same thing but from the posts I've read and people I have talked with they say the wrap retains moisture.
Another option to consider is heat shields where you can.
Yes have plans to install one between the headers and steering bushing.
Get both, worth a shot, not my money
Yes it's fun to spend other peoples money.... :ROFLMAO:
toximus
I live in my Jeep
Northern WI
Might be worth looking into what the highest grade stainless steel exhaust tubing is to prevent rusting through. It might pay for itself. Plus it'd be a pain to diagnose where a wrapped leak is...
BuildBreakRepeat
Occasional Genius
Stainless steel also has a lower thermal conductivity than mild steel so a slight insulation will be gained just switching to that.
Reactions: Wildman
Wildman
Wildman
Staff Member
In the hills of WA
From my header back it is going to all be stainless tubing for the exhaust. 2.5" from the collectors to the Y and then 3" from there to the back of the Jeep. With no fuel tank in the way I shouldn't have too many issues I hope. Got a round cat which should work good and haven't bought the muffler yet as I want to see how much room I had first.
Figured I'd slap the heads on and mock up the Y pipe and then if I was going with ceramic coating then take them over and have it done while I worked on other things.
BuildBreakRepeat
Occasional Genius
Header wrap sealant I just saw.
Chris
Administrator
Staff Member
Florence, AZ
Mark my word, it will cut the temps DRAMATICALLY! Just wait and see, you’ll be blown away. I’m having my header system and exhaust done as well for this very reason. This stuff really works wonders 👍
Just make sure you ceramic coat, DO NOT wrap.
Reactions: Ephry73
