I haven't found one on this forum. Do we have one yet? Anyone know of any on other forums, with pics or a vid?
Of course I will also read the FSM, but I always find that a good walk-through post brings a lot of clarity to the FSM diagrams.
Edit: Some Pro Tips from this thread are below ...
- Preparation:
- Put painters tape on electrical connections and label before disconnecting.
- Can remove fender for extra room. But on 2.5s, most say there is plenty of room to work.
- Some aftermarket manifolds come with heat shields. Remove them, or be prepared to bend and cut for fitment.
- No special tools required, except:
- 14mm flex socket (or 15mm in some 97s). No, a universal will not do.
- Various socket wrench extensions: 3", 6", etc. At one point I was using two 6"s and a 3".
- Fuel line disconnect tool. In a pinch, you can get creative with plastic tubing.
- Maybe an angle-grinder, if your manifold requires grinding. See below in "process" for details.
- For ideas of other jobs to tackle while you're at it, see here.
- Process:
- RaymondT shared the updated/revised order of torquing bolts, here. Maybe the same exists for 4.0s?
- If you pull the fuel rail, keep up with the o-rings. Some say to change them. Or a little lube to slide back in.
- Replacing intake manifold is delicate. If not seated properly, will cause vacuum leak and sky-high engine rpms.
- If you find oil smeared in your intake manifold or throttle body, clean throttle as described here.
- Most replacement manifolds require grinding to match thickness to intake manifold.
- See here and comments above for what needs to be ground down.
- But, difference in thickness could be due to choice of gasket? See here and here.
- I had good luck with the Dorman, purchased through Summit. No grinding required.
- If you do have to grind, angle grinder 4-1/2" with 1/16 cutting wheel apparently works.
- Finally, see @PauoaTJ's notes on the process here. (Closest thing to a walk-through on this forum.)
- Follow-Up:
- If you get lots of smoke a few minutes after first post-install start up, see this thread.
