Jackjack97 TJ Enthusiast Joined Apr 7, 2020 Messages 247 Location Sacramento CA Nov 27, 2020 #1 Do I need extended parking brake cables for a 4.5 inch lift?
BuildBreakRepeat Occasional Genius Supporting Member Joined Jan 21, 2019 Messages 3,371 Location McKenzie Bridge, Oregon Nov 27, 2020 #2 Jackjack97 said: Do I need extended parking brake cables for a 4.5 inch lift? Click to expand... @mrblaine Do you normally rework the bracket? I found I had enough cable for mine to work after messing with the adjuster.
mrblaine Crew Member Supporting Member Joined Nov 20, 2015 Messages 28,971 Location Quail Valley, CA Nov 28, 2020 #3 BuildBreakRepeat said: @mrblaine Do you normally rework the bracket? I found I had enough cable for mine to work after messing with the adjuster. Click to expand... Haven't yet.
