Fair Price for a TJ Dana 44 Housing?
Those upper mounts aren't stock. I don't know enough to be able to judge the quality of the work. Unless I knew a lot more I'd be hesitant.
Reactions: sjinatl
good catch. Might be worth measuring them to see if the holes are in stock locations just with beefed up brackets, or something different like a geometry correction....although the fact that I don't see any sign of redrilling the lower mounts probably points toward stock locations.
Reactions: sjinatl
I think I'm going to pass on this axle. If it were close I would go look at it. Unfortunately it's 4hrs away.
I'll just keep looking.
Mounts can be easily added. Ask for close up pictures of the bearing caps. If they match, offer $250 and see what they say. If you're re-gearing, that's the time to go selectable locker and upgraded axles. If the housing is straight, that's a great deal at $250 - $300.
Reactions: hosejockey61
