All I can tell you is that I work on shocks, a lot. Not my job to do your research. Which I suggest you do. Maybe take one apart yourself?So in asking you to post up mfg data/info you offer up more condescension with a trust me...xyz is _______ because I said so.
Nice
The name "remote reservoir" means that the nitrogen is stored in an external reservoir. They way that works is there has to be a divider piston. That piston is called a floating piston , because it floats and only moves the amount of the shaft displacement.
