So almost spring, time to do that mod I've been planning for the past year. Went from 33x10.50s on ProComp wheels to the same on the stock 5 spoke steel YJ/TJ rim. And the 6" flares look like pantaloons.
So time to slice the flares from 6" to 4.25".
Basically 2 cuts. Leaving 1.5" attached and making a 1.5" strip to use as a bonding joint.
And cut 2
Strips for the connection
And the final fit with screws first. I'm amazed how solid they are.
Will be pulling it all apart once warmer weather hits to glue it together and do some kind of a boxliner or krinkle paint to dress 'em up.
And cut 2
