Bear with me, this is going to be a bit longer than I hoped...
We've been discussing this issue in my build thread for a few days now, but I decided it was time to make a thread entirely for the issue.
( there are plenty of threads like it, however I can't figure out some of the answers I need )
Not to mention driveline angle lingo gets confusing depending on the context...
I've got a 2006 LJ, with 4" Suspension lift.
Factory/OEM Driveshafts.
Full Adjustable Control Arms.
4.88 Revolution Gears. (adding this because i'm un-familiar with gearing, or if there are any gearing-related vibrations)
I've got mystery drivetrain vibrations
( slight vibration around 30mph but goes away around 35mph, with a more audible noticeable vibration starting at 65mph and getting louder with speed)
It is text-book example of driveshaft vibrations , as the typical VROOOM - VROOOOM - VROOOOOM "drone-y" sound.
Similar to a sine wave.
It's not an aggressive vibration, as it's rather mild, but still I know that ANY vibrations can wreak havoc on joints/bearings/seals.
I took the incentive this morning to pull my front driveshaft out, so that the issue could be isolated front/rear.
The vibrations were still there, so it can be ruled that the issue is not in relation to the front driveshaft/axle.
So it is contained entirely to either my Transmission/Transfer Case, Rear Driveshaft, or Rear Axle/Pinion.
I used my Klein Digital Angle finder on the Rear Pinion, as well as the rear Transfer Case Output Shaft.
Rear Transfer Case was read to be 8.4 Degrees - as measured from the top of the harmonic balancer, as well as the driveshaft knuckle.
Rear Pinion is set to a matching 8.4 Degrees - measured from the flat/machined spots on the rear of the housing.
I have since tried to adjust the pinion angle to 7.9 Degrees with no discernable change to vibrations (0.5 degree difference to Output Shaft to account for axle rotation).
Here's where things get interesting.
At 70mph, during the vibrations, if I push the clutch pedal to the floor the vibrations stop entirely.
The same happens if I let OFF the gas pedal, and coast downhill.
The vibrations seem to be following/related to drivetrain load.
(which theoretically COULD still be a pinion angle/axle rotation based issue)
Now the fun part.
There's a ton of 'fixes' for vibrations, all of which I am willing to try.
MML seems to be a hot topic in the vibration threads, as well as a slight transfer case drop being another common one.
SYE/CV is top priority for vibrations (however, I currently see no need in wildly throwing $600 at it in hopes of fixing the issue)
I'm willing to pick up a few washers, and drop the Transfer Case temporarily to see how/if that changes things.
But I do have some concerns with that method.
It's been pretty heavily regarded that a transfer case drop is needed with the factory YOKE style driveshaft, EVEN IF you have adjustable control arms.
I've read that on about 10 different threads in the last 20 minutes, and it just makes absolutely zero sense to me as to why.
The transfer case drop essentially just changes the angle of the output shaft/driveline, to better align to your rear pinion angle.
It's a 'band-aid' fix at best, but that is all I need at the moment until I can figure out exactly what is causing the vibrations.
However, seeing that I already have fully adjustable arms, I can ALREADY match the pinion angle to whatever the transfer case angle is.
Does that, or does that not, render playing with Transfer Case angles useless in my scenario?
(it is also worth keeping in mind the length of the LJ driveshaft already. It sits a LOT flatter than the TJ rear shaft)
At this point, I am willing to try anything/everything to at least verify what is causing the issues/vibrations.
There are a lot of people in this forum smarter than myself, hence why I felt the need to add all the information, as well as reach out to you guys about solutions.
If there's any information I left out that could be useful, let me know. I'm willing to measure/photo anything that is needed.
Now the fun part.
