After 5+ years of constantly cleaning the garage floor and then getting a drip tray, and then adding kitty litter to the said drip tray, and buying oil by the quart, and adding oil by the quart and then cleaning the floor again because I forgot to move the drip tray back under the jeep, I finally got tired of managing/dealing with the RMS leak on our '03.
I've tried the RMS leak sealer and it resolved nothing except where to spend $14.
I've also read many posts about changing to 'high mileage' oil as a solution, so I finally figured why not give it a try on the next oil change...
I had always suspected these additives to be more snake oil than motor oil, but I'll admit that I was wrong.
Swapping from conventional 10W-30 to the high mileage, (also conventional) 10W-40 has improved the leak significantly.
I'm not naive enough to think the leak will totally go away, but it has decreased the amount of drips by about 75-80%, which is good enough to avoid replacing the RMS for the foreseeable future.
I would have gone with 15W-40 High mileage if I could have found it locally. Maybe next time.
