Long story. So I broke my Eaton E-locker. Parts are backordered. So I bought an ARB thinking that would save time. And even though this took awhile the parts for the Eaton still haven’t shipped. But I kept having the shims for the arb crush when trying to set preload on the locker since I couldn’t use a typical case spreader due to the axle truss for the Upper four link mounts. So I decided to build brackets and use a port-a-power jack to use as a case spreader. It worked out great and all is well and backlash is in spec at .009”. I will get the new axle bearing and seals pressed on tomorrow and reverse the brake brackets with the Wizard kit and get this thing all back together tomorrow.
