So about two weeks ago I purchased a used 02' Jeep TJ... Checked the oil the day I drove it and it was the normal used oil in need of a change. Coolant levels looked fine so I figured I'd take it for a few drives over the weekend I bought it. I drove it about 200 miles and everything seemed fine. We had a cold front come through and I noticed that my heat wasn't working when I decided to drive it to work one day. Well — that is where it gets fun.
I'm driving to work on the interstate running 65-70 and I noticed the temp gauge rapidly climbing suddenly. I figure I should pull off and see what's going on. It jumped from 220 to 260F in a a matter of 20 seconds. I pulled off the shoulder to the sound of wooshing and steam/smoke coming out of my a/c vents. I immediately cut the engine and let it sit for about an hour while my neighbor came to pick me up and see what happened.
Once the Jeep cooled I opened the radiator to discover it was very low on coolant and there wasn't any in the reserve tank... We both figured the heater core is toast and it leaked all my coolant away over the weekend of driving it. I filled up the coolant levels with 50/50 and has been parked in my driveway since. I bypassed the heater core until I can work on it this fall. Since doing the bypass the coolant levels looks fine and the Jeep doesn't get much over 185 F when driving around in the evenings when I tinker with it.
Since overheating I've ran Seafoam through the tank as well as using their top engine cleaner (sprayed into intake) and it's been sounding much better. Well, last night I go to change the oil and this is the color I see pouring out from the drain plug... The motor sounds just like it did when I bought it and I haven't noticed decreased performance. Is this normal from running Seafoam through the engine. Hoping to get some other opinions from you guys.
