Happy New Year everyone!
I have a problem, that just recently started but is quickly getting worse. I have a 97 TJ 4.0 manual with plenty of lift on 35's. About 2 weeks ago, I started to feel a vibration. Not a high pitch vibe. More of a low pitch shake/oscillation akin to an out of balance driveshaft. I actually was hoping that that was the problem, but I wasn't that lucky.
The abnormal condition does not seem to be tied to engine RPM. More to vehicle speed regardless of RPM. It is worse in 2wd and almost completely disappears in 4wd. I have tried it in 4 high and 4 low. It is still there but greatly reduced. If I press the clutch in while it is shaking, the shaking is also greatly reduced. It shakes worse if I step on the gas hard and make the drivetrain work.
It was pretty faint when it started. My daughter borrowed it last week while her car was in the shop. I estimate that she put no more than 100 miles on it. The shake has gotten considerably worse in that time, so something has changed/is changing quickly.
Today I tried to do some in-depth diagnosing. Here is what I have done and the result:
Removed the front shaft and went for a ride. Still shakes. Put it back in.
Removed the rear shaft and drove in 4wd. Shake is almost completely gone.
Noticed that a u-joint was dry on the rear shaft, so I replaced it before putting the shaft back. Still shakes.
At this time, I am thinking something is wrong in the TC, but I am not sure what it could be that would cause this issue. It shifts in and out of 4wd without any issues or noise. There is no discernible noise from anything during the shaking and the Jeep tracks straight. This is not a DW kind of shake. I seriously was sold that it was an out of balance shaft until now.
Any thoughts on where to look next would be greatly appreciated.
