SOLD Flex-a-lite Transmission Cooler
PurpleTJAZ
Arizona
Price
$60
Arizona
Flex-a-lite direct fit transmission cooler. This bolts in using the grille V-bar bolts then just running some hose to the cooler from the radiator. No fabrication or weird zip ties. I have been using it with the radiator bypassed for the last couple years and it stood up to the Arizona heat. Just changing my set up to make room for a p/s cooler in the grille area. $60 pick up or I can ship at the buyers expense.
Reactions: Lax22
Hi,
Very interested.
What would shipping be to 46060?
Any pictures of it installed?
Thank you, Daubie3
Thank you..
There is no fitmit issue with having A/C on the Jeep.? And it just uses slip on hoses with clamps?
Hi,
Very interested.
Thank you, Daubie3
So a quick check of USPS parcel service. 5 pounds from 85382 to 46060 (zone 7) is about $18.00
Thank you..
Yes , I have factory a/c. It all mounts forward of that in the grille area. Just a simple slip on clamp.
