Hi guys. The fog lights that came with my Jeep worked fine until I did one of two things. I did them about the same time.
The first thing was to install an aftermarket bumper. I temporarily had to, and currently have, the wires pulled pretty tight to reach the new location. I undid the electrical tape bundling the fog/turn/other lights together to get the extra length. Even after this however the fog lights worked. Also the switch still works and lights up, as does all of the other lights.
The same day or next day I ran wire to install that sound ordinance sub I heard good things about. Sub works great everything on the Jeep is fine except the fog lights don't seem to be getting power.
I turned them on and put a wiggy to the wires and got nothing although I'm not sure a wiggy (like a volt tester that wiggles) would register or not. I've tried to follow the wires from the switch with an endoscope but get lost. I did find a wire harness in the area I was working on the sub that is hanging loose so I'm thinking this may be it? But I can't find anywhere to plug it in.
The attached picture is of the loose wire. It is driver side and goes through the firewall between the two rubber plugs in that area. It seems to disappear into a cavity though because I can't locate it in the engine bay.
Thanks in advance
Thanks in advance
