So my 02 TJ continues to trump me on HVAC problems.
After resolving the resistor issue and getting the fan to work, i still found that the directional controls failed to function. I checked the vacuum lines and all seems good and I cannot hear any leaks nor when spraying with soapy water do i see any bubbling or air movement being pulled in. I don't have an actual tester.
So i ordered and replaced the module that the vacuum lines connect to. In the process, the battery died. So after replacing the battery i was finally able to test to see if the control module fixed my issue. it did not. I also found that the actual knob itself is broken which would explain part of the problem (i've since ordered a replacement knob).
So in testing, some functionality does work.
Off = Off
Max A/C = Max A/C
Vent A/C = Vent A/C
Floor / Vent A/C = Floor / Vent A/C
Vent = Vent
Floor = Floor and Vent - This is where the problems start
Floor / Defrost = Floor / Defrost / Vent - Again air out the vent when it shouldn't
Defrost = Defrost / Vent - more Vent
So in all modes besides off, i always get air out the dash vents. Any thoughts on this?
Off = Off
Max A/C = Max A/C
Vent A/C = Vent A/C
Vent = Vent
