Hey everyone. I am planning to change up my Jeep's suspension and will be selling various components. I am looking to remove these from the Jeep in August and sell everything then so my rig won't be without legs for very long. All parts fit '97-'06 TJ's and are in great used condition.
This is one of the best suspension solutions for a Jeep TJ.
All parts are in perfect working order. You pay shipping.
Parts for sale:
Parts for sale:
- [SPOKEN FOR] Savvy Double Adjustable 6061 Solid Aluminum Control Arms with Johnny Joints - $750
This is the complete set of 8 Johnny Joint® Control Arms. All arms are fully adjustable allowing the pinion angle and caster angle to be adjusted. This adjustable feature allows your vehicle to be upgraded to different lift amounts without having to replace the control arms in the future. The lower arms are made of 1.5" Aluminum and the upper arms of 1.25" 6061 Aluminum rod drilled and tapped both ends with a wrench flat. All arms are raw aluminum and come with Johnny Joints with grade 8 mounting bolts. The uppers are double adjustable so you don't have to remove a bolt to dial in the pinion angles. To allow complete unrestricted movement, the Johnny Joint® is used at both ends of all 4 of the rear arms, both ends of the front lowers, and on one end of the front upper arms.
- [SPOKEN FOR] Currie Johnny Joint Rear Track Bar with Currie Relocation Bracket kit (CE-9123N) - $275
The Currie Rear Track Bar with Bracket for Jeep Wrangler TJ and Unlimited (LJ) includes all of the same features as Currie’s trail and race proven Johnny Joint front track bar and is the perfect complementing unit to the front bar to optimize your Jeep TJ/LJ’s articulation.
- Currie 4" Progressive Coil Springs (CE-9130H) - $275
These heavy duty 4″ coil springs replace factory springs and are designed to work with Johnny Joint® suspension systems and otherwise. This set features our standard front springs and our heavy rate rear springs. Springs are designed to provide a 4″ lift. Extensive research was done by Currie to develop the perfect combination of rates and quality of the coil springs. The results: they provide the best in comfortable ride and excellent performance on the rocks. Powder coated finish. Price above is for a set of 4 springs (2 front and 2 heavy rear coil springs).
