Nearly a month later and it's even better now. My nighttime trips to the bathroom have cut way down from before the procedure. Still getting up just once vs. up to a half-dozen trips before. "Urgency" is pretty much gone where before it was often 'gotta go gotta go!' The stream strength is way up too, the reduced restriction really helped there.
When you guys start noticing BPH, not if but when, and it gets so it's decreasing your quality of life, definitely look into a Urolift procedure. It's about the only one that really helps with BPH symptoms without several permanent side effects like more invasive procedures that use lasers have. No sexual side effects either, in fact even that's better lol.
