I think this engine will become a very popular and well-supported swap in the next few years. Dozens of companies are already working on various supporting products for the platform.
It also has the possibility of becoming one of the most versatile engine platforms available. This engine is built for reliability and easy serviceability, and as such is very easy to work on and quite tolerant of modification. These engines are intended for consumer as well as fleet usage, and unlike consumer markets, fleets are very concerned with maintenance costs, especially labor. So the engine is quite simple to work on. Rumor is the engine internals are strong enough for moderate forced induction builds.
As for transmissions, there are a lot more transmissions that can be adapted to the Ford Modular V8 platform than I listed. I mainly chose those ones because they are popular with either the Coyote or Godzilla.
For 1st gear ratios, the 10R80 or 10R140 transmissions have a 4.69:1 1st gear, and a 0.63 10th gear. That is simultaneously a deeper 1st than any TJ auto or manual, a taller OD than any TJ auto or manual, and a much larger span than any TJ auto or manual. Plus the gears are quite close to one another, so there is almost always a near-perfect ratio for the speed you are traveling.
As for manual transmissions, there are a lot more available than I listed that just require an adapter that is already on the market. Even with a direct bolt transmission like the Tremec TR-9070, it could easily be installed with 5.38 or 5.89 axle gears in Dana 44 axles (as deep as 7.17 with D60s) to have the effect of a super deep 1st gear while still having mild freeway manners with its 0.50 overdrive.
Other transmissions you can buy adapters for already:
- Tremec T90
- Tremec T14
- Tremec T86
- Tremec T15
- Tremec T18
- Tremec T98
- Tremec T19
- Bronco II / Ranger 4-speed
- Bronco II / Ranger 5-speed
- Aisin AX-15
- New Venture NV3550
- New Venture NV4500
Also, I missed the ZF S6-650, which will bolt directly to the Godzilla. This transmission has a
5.79:1 1st gear and a 0.72:1 6th gear, making it a potentially awesome option for a manual transmission. Rated for 530 ft-lbs, it should easily survive a stock or lightly modded Godzilla.
