So I told my parts guy I needed a Ford 8.8 rear end out of a 96 to 2001 Ford Explorer and this is what he brought me. The left side is 17 in the right side is 20. Shouldn't the knuckle be centered for it to be a good swap in a 2000 TJ?
How in the world did you get the vibration out. My rear yoke is 16.1* and DS is 18.1* but can’t get it out bc of the offset I’m guessing. Wonder if I can unbolt the motor and tranny mount to maybe crank it a bit straighter?? Vibration is at 65mph+Like Jerry said, they all are. Mine is offset and I drove around on the stock driveshaft for a year without vibration or excessive wear. I know the fabricator did spend quite a bit of time dialing in the right pinion angle to get rid of the vibration it started with though. After I got my SYE and new driveshaft just a month ago its still vibration free so make sure you are prepared to put in some tuning time
Sent from my SM-N950U using Tapatalk
Did you install an SYE, DC shaft, and adjustable control arms?How in the world did you get the vibration out. My rear yoke is 16.1* and DS is 18.1* but can’t get it out bc of the offset I’m guessing. Wonder if I can unbolt the motor and tranny mount to maybe crank it a bit straighter?? Vibration is at 65mph+
Have been very happy with my 8.8 swap over the years. I'd recommend the c-clip eliminator kit from yukon but it is pricey.
There are two things Jerry does not like, Ford 8.8 and High Lift jacks. There should be a warning for everyone here that if you mention either one, Jerry is going to let you know he does not like either one.
And we all know what they said about "OPINIONS". And yes I have some also and a lot of them stink too.
I have to poke fun, every time 8.8 shows up here, here comes Jerry!
You should try bringing up Long Arm suspension lifts.... Then you get to see a picture of Jerry hung up on a rock too.
