Brantley
If I dont have all the info I can not make a good justifiable decision. Y'alls info is what I need.
What engine, transmission, and tire size are you dealing with?
No doubt. The gears would have to be redone. I don't know how. Closest guy I know and trust is two hours away, So jeep has to be towed. Not sure of price to set up existing gears.Disclaimer: I just got back into wheelin and it has been 25+ years since I was doing gears professionally.
But, I don't get the whole 8.8 thing. Is it because it is cheap to come by? It has a weak limited slip, isn't ridiculously strong, has an odd offset, and needs a bunch of fabrication to install into a TJ. Reason I ask is years ago we all built 44's, Ford 9", Dana 60, etc. The 8.8 wasn't even a consideration.
That said, if the S35 is going to do all you need for your wheelin style, why not? You could get it installed literally in a couple hours, less if the backlash sets up correctly the first time. Add an extra 1-2 hours if running an ARB for compressor and plumbing install.
Why would it have to be towed? Aren't there gears already installed?No doubt. The gears would have to be redone. I don't know how. Closest guy I know and trust is two hours away, So jeep has to be towed. Not sure of price to set up existing gears.
oh thats for new gears. my bad.ill have to call and ask how much he would charge to reset gears. and install a locker. Jerry what locker do you run in your jeeps rear end axleWhy would it have to be towed? Aren't there gears already installed?
4.0 6 cyl , 5 speed 33s on 15" wheelsWhat engine, transmission, and tire size are you dealing with?
I installed a Detroit Locker into my first TJ's rear Dana 44, my replacement TJ has f/r Rubicon air lockers.oh thats for new gears. my bad.ill have to call and ask how much he would charge to reset gears. and install a locker. Jerry what locker do you run in your jeeps rear end axle
im guessing the air locker would be better choice for daily driver ?I installed a Detroit Locker into my first TJ's rear Dana 44, my replacement TJ has f/r Rubicon air lockers.
Some people believe so but I was perfectly happy driving my TJ around every day with its rear Detroit Locker. For me, it was well behaved enough that I still miss it. You can't go wrong with a selectable locker but I certainly don't look back on my previous Detroit Locker with anything but good memories. I would only consider a Detroit Locker to be a less-than-desirable choice in areas that get icy or snow-covered roads during the winter, something you're not likely to see there in MS.im guessing the air locker would be better choice for daily driver ?
4.56 will be much better than your planned 4.10's.4.0 6 cyl , 5 speed 33s on 15" wheels
4.10 "works" with 33" tires, 4.0L and 5-speed transmission, but it basically sucks compared to the 4.56. I regeared to 4.10 for 33" tires about 16-17 years ago before I knew better and within a few days, I was was really pissed at myself for not having listened to those who kept recommending 4.56. The 4.10 gearing basically sucked with 33's, it was barely ok on flat ground but I had to downshift continually to get up even the slightest of grades.4.56 will be much better than your planned 4.10's.
Yesyea maybe someday i will be able to re-gear. If i went to 4.88 would
that be good for 33 and 35s ??
Is there any reason one of these setups wouldn't work on an MJ with a Dana 35? I have a long wheelbase one I was looking at putting an 8.8 into ( I actually already have it, 3.73 LSD) but I am looking for towing and payload capacity rather than off road capability on this one. A long bed MJ has a 120" wheelbase, and the Dana 44 heavy spring units were rated to tow 5000lbs and had a 2200lb load capacity stock. I have a small camper I want to tow with it, this S35 may be the ticket.
What year is it? Anything before 1991 I believe had bolt on axle shafts and 1991-06 had c-clips. Or maybe it was 1990-06. I'm not sure. As long as you have c-clips, you should be able to do it.
