Ford Dana 44 Front Housing - $250 OBO
Fouledplugs
1,917
Alabama
Bought this Ford (driver side drop) Dana 44 front housing with the idea of pressing in new tubes, new inner C’s, and using TJ outer guts to have a front Dana 44 to match my rear.
However, this housing has a leaf spring (spring under) provision cast into the housing. So its a no-go for me and the TJ.
$250 OBO, money talks. Located in Birmingham, Alabama, local pickup only.
Can deliver to Georgia or South Carolina for gas money.
astjp2
732
Utah and Alaska
I actually have the same housing and am going to use it on my LJ. It will be narrowed down from the 67 WMS to 60 and I will marry it to a rodeo rear. I have a similar setup in my YJ, so I have the brakes figured out. Now I just need to figure out mounts for the LJ. These HP housings are a keeper IMO. Tim
Reactions: Fouledplugs
Fouledplugs
Fouledplugs
1,917
Alabama
I guess I’m just OCD. The only reason I dont want to use it is because of the spring pad that is cast into the center section. I just thought someone may want it more than I would with the same thought, narrow it and use it in a TJ/LJ.
