Ford Dana 44 Front Housing - $250 OBO
Fouledplugs
TJ Guru
Alabama/North Carolina
Bought this Ford (driver side drop) Dana 44 front housing with the idea of pressing in new tubes, new inner C’s, and using TJ outer guts to have a front Dana 44 to match my rear.
However, this housing has a leaf spring (spring under) provision cast into the housing. So its a no-go for me and the TJ.
$250 OBO, money talks. Located in Birmingham, Alabama, local pickup only.
Can deliver to Georgia or South Carolina for gas money.
I actually have the same housing and am going to use it on my LJ. It will be narrowed down from the 67 WMS to 60 and I will marry it to a rodeo rear. I have a similar setup in my YJ, so I have the brakes figured out. Now I just need to figure out mounts for the LJ. These HP housings are a keeper IMO. Tim
Reactions: Fouledplugs
I guess I’m just OCD. The only reason I dont want to use it is because of the spring pad that is cast into the center section. I just thought someone may want it more than I would with the same thought, narrow it and use it in a TJ/LJ.
