https://www.facebook.com/marketplace/item/671148010238275/
76 thick tube ford high pinion dana 44 narrowed for jeep yj. Picture was taken before being narrowed. Housing was cut down to 1980 wagoneer width to use off the shelf axle shafts. Inner c's were welded inside and out, will probably need some grinding on outer welds to keep shafts from rubbing. Need to go low pinion for clearance due to engine swap. Has 3.50 gears open diff that can go with if you want. No other parts are included. Sell for 400 or trade for a 1980+ driver side drop wagoneer dana 44 that's complete. let me know, thanks.
