End terminations and such like soft shackles should be considered disposable. As in you should have several, keep an eye on any wear or damage they have before use and dispose of any that are suspect. Also why you need to be able to acquire them cost effectively. If they are cheap enough, then you can have several on hand and get rid of the bad ones.
What's wrong with Factor55?
One of the goals of safe rigging in vehicle recovery is to reduce the amount of connections. Historically, Factor55 has been antithetical to safe practices.
Which I would think would be the biggest strike against their design. A lot easier and cheaper to replace a soft shackle vs the whole rope. Even if you replicate what they did you’d lose over 10ft of rope.
So what kind of winch shackle would reduce the number of connections from what you posted?
Seemed like more of a time saver idea since a thimble and soft shackle does the same thing with safety and mounting just the fact you don’t have to pull stuff from in the rig to use it. Absolutely died when I saw the screen shots of the forum pop too.
Agreed, it's an interesting design, but I can't see a situation where it works better than a soft shackle and tree saver.
The ability to form a loop with the winch line itself is cool and all, but 90% of the time I'm winching off a tree, where a tree saver is preferred. I imagine it might be useful if you mainly winch off of large rocks.
Matt (Offroad Recovery) said that he was going to replace his Freedom Rope even though it was in good shape because it had been used a lot. That's just dumb. If it's in good shape you keep using it.
I assume Matt will get a new rope for free from Matt.
He got the first one for free. He mentioned that.
The thing is that if I expected a lot of winching one day on the trail all I'd have to do is attach my soft shackle to the safety thimble and toss it over the recovery hook. When I needed the winch someone can just run up there and release the brake and grab it and run. No different than what he's doing. Nothing novel that I am interested in because the part about using the rope doubled over as a tree saver is not a practice I want to follow.
In all fairness, that may apply to the average user but if offroad recovery is your business and you're using the winch on a regular basis (possibly daily) I see it as preventive maintenance. Replacing a $300 winch line after two or three years in his business is about the same as one of us replacing a soft shackle.Matt (Offroad Recovery) said that he was going to replace his Freedom Rope even though it was in good shape because it had been used a lot. That's just dumb. If it's in good shape you keep using it.
I left a soft shackle on my front bumper attached to my hook and proceeded to damage the soft shackle on a rock.
On the floor next to the seat is where I keep one and the rest are in a backpack snapped to the roll bar ready to grab and go.
if it's good, it's good. If it's compromised, it's not good.
It's possible to damage the soft shackle if it's attached to a safety thimble that is stretched over to a hook on top of the bumper, but not common. You'd literally have to hit the top of the bumper edge (not the lower edge or front face) to do it.
