B Brad W TJ Enthusiast Supporting Member Joined Nov 8, 2018 Messages 264 Location Black Hills Jan 12, 2019 #1 So today I took the bad bushings out and installed the new ones. Come to find out the old bolts are to big for the bushings :BangHead:. What do you guys recommend for a new bushings and bolts kit?
Chris Administrator Staff Member Ride of the Month Winner Joined Sep 28, 2015 Messages 70,955 Location Florence, AZ Jan 12, 2019 #2 For new bushings I think it’s easier and cheaper to just get new factory arms with bushings already pressed in, such as these ones: https://www.amazon.com/gp/product/B01MPVWEBY/?tag=wranglerorg-20 If you need new bolts, your local ACE Hardware should have everything you need.
OP B Brad W TJ Enthusiast Supporting Member Joined Nov 8, 2018 Messages 264 Location Black Hills Jan 12, 2019 #3 Chris said: For new bushings I think it’s easier and cheaper to just get new factory arms with bushings already pressed in, such as these ones: https://www.amazon.com/gp/product/B01MPVWEBY/?tag=wranglerorg-20 If you need new bolts, your local ACE Hardware should have everything you need. Click to expand... I don't need new arms. I have adjustable JKS arms. I just need new bushings that are for the front Axel on top of the diff. And shaft.
