I don’t have the skill to drive my Jeep like some of you folks. Rock crawling and all. I’m happy tooling about on service roads and moderate trails. That being said though, I would like to have front lockers installed, for the day I botch it. I have ARB in the rear. I just like to know I’m at least as capable as the friend I go with many times, he has a Rubicon. When the rears were installed when I was having it re-geared the guy that did the work said that when doing the front I should change from the 27 spline to the 30 spline. It’s a Dana 30 diff. That’s what I recall, of the conversation. He said it would be stronger or something along those lines. He does a lot of gear changes so I believe he knows what he’s talking about. I’m looking for a good maker of axels. Maybe I can afford what is considered best, but in the event I can’t, what’s next in line? Need to put together the money for this. I ran out of cash when doing the rear and since I had lost a bearing back there, I was forced to do it right then.
I have an 03 Sport 4.0 with a Dana 44 in the rear, Dana 30 in the front and air setup and ready for the front ARB lockers, even wired the switch.
Sent from my iPad using Tapatalk
