I am adding a very minimal lift (1" - 1.5" expected) and am trying to determine what bump stock extensions (if any) are needed and which specific RS5000X shock to go with. Running 31" tires with the longer term potential of 32" tires at the most doesn't have me as much concerned about up-travel, it is really down-travel... let me try to explain.
This is for my TJ only, your dimensions may be slightly different - but shouldn't be by very much
The stock suspension at rest (curb height) has a delta of 13.375" between the height of the shock (17.5") and the height of the bump stop over the spring perch (4.125") - (17.5" - 4.125" = 13.375"). This means the Rancho RS5000X shock for 0" of lift (p/n RS55128) would fit fine as it has a compressed length of 13.050". This means that on full compression of the suspension, the bump stop will limit up-travel and the shock will not bottom out. It also means the suspension has an up-travel of 4.125" (bump stop allowed travel) and a down-travel of 3.53" calculated by 21.030" (fully extended shock length) minus 17.5" (curb height length).
So now let's look at it when we add 1.5" of lift and stay with the shock for 0" of lift. The curb height length of the shock increases to 19" and the bump stock limited travel goes to 5.625". Staying with the stock shock will allow the full range of up-travel as the delta remains at 13.375" and the shock is still only 13.050" fully compressed. As far as the wheel goes, this doesn't change from stock as the upper limit of travel is the same as it was with the stock suspension, it only starts from a lower position. However, using the Rancho shock for 0" of lift will now significantly limit down travel to 2.03" calculated by 21.030" (fully extended shock length) minus 19" (new curb height length). Assuming the shock limits down-travel, this means down-travel has been reduced significantly. We can debate for hours why this is not a good thing on a 4WD vehicle.
Ok, so now let's look at moving to the next size up Rancho Shock, the one that states 2.5" of lift (p/n RS55239). In this scenario, the compressed length of the shock is 14.430". This means we will need a bump stop extension of min 1.055" (14.430" - 13.375" to stop the shock from bottoming out during suspension up-travel. I am not a betting man so I would opt to go for a 1.25" to 1.5" bump stop extension. This will limit the up-travel to between 4.125" - 4.375", which is equivalent or slightly better than stock. in this scenario, down-travel ends up at 4.840" calculated by 23.840" (fully extended shock length) minus 19" (new curb height length w 1.5" lift). The down travel is now better than the stock setup, making the vehicle much more compliant off road.
Everything about this points me in the direction of the Rancho RS5000X for 2.5" lift (pn RS55239) and a 1.25 - 1.5" bump stop extension. My questions to the experienced on this forum are:
1. Do you see any flaws in my logic?
2. Would you go with a 1.25" or 1.5" bump stop extension and if so, do you have any recommendations - I like the metal 1.25" JKU ones for the bottom spring perch
3. Would you mount the spacer on the bottom spring perch or above the bump stop cup.
