front end slightly lowered
TJCR
I have a 3-4" suspension lift, body lift is 1.5", I am running 33X12.5 tires, tube fenders. There seems to be plenty of room to lower (stance) the front end about an inch. Would this be as simple as shaving body lift spacers at the correct angle towards the front? Appreciate any words of wisdom of pro's and con's.
Thank you.
Don't do this via the body lift. If you want to lower the front end 1" the best way would be to lift the rear 1" more (via a spring spacer).
Reactions: TheFrenchMan
Cutting down the spacers would start flexing the body. I would do what Chris said and get some spacers for the rear springs.
