Factory toe-in .30 total. Assuming 35" tires, 4.5 minimum but 5-5.5 degrees of caster angle is better if you can get it.
DoesFactory toe-in .30 total. Assuming 35" tires, 4.5 minimum but 5-5.5 degrees of caster angle is better if you can get it.
No, the caster angles are designed to be slightly different from each other.Should caster angles match R-L on alignment sheet?
So this alignment sheet does not call for any adjustments on a Jeep that has adjustable CA, TB?No, the caster angles are designed to be slightly different from each other.
Yes, my question is, does this printout suggest the need for any adjustment if one has adjustable control arms and track bars?Did you intend to add a comment along with that printout?
As said a couple times your numbers are fine as-is.Yes, my question is, does this printout suggest the need for any adjustment if one has adjustable control arms and track bars?
