TJ Fest 2021 Hats
Order your Jeep Wrangler TJ Fest 2021 hats today! Click here for ordering instructions.
Front Suspension Cycling Results
Impact LJ
Tampa, FL
So today I tried to cycle the front suspension to set bump stops and see what shock I'm best off going with.
As of this morning, I have no bump stop extension with a 3.5" lift installed. After my most recent wheeling trip, I realized I had enough rubbing to damage my front fender from the up travel.
The original plan was to add 2 hockey pucks bolted into the spring pad with a 1/2-13 bolt in case I needed to go with the Currie setup.
After realizing the jounce bumper does very little in terms of stopping up travel, I needed to add more. About 1.5 inches more the way I see it.
Here is where I need the up travel to stop and how much shock shaft I would have showing when that happens. It seems like quite a bit and something I could stop with a spacer on the top of the shock under the mount.
What are you guys using as a spacer on top to maximize shock travel? Or am I better off going with the longer version?
These are the measurements of the shocks and mount:
freedom_in_4low
Monument, CO
probably wouldn't hurt to fill out your profile so we have more info about your rig.
I have 3" of total bump stop extension which matches perfectly with Rancho RS55255 front shocks in factory mounts and nothing else makes contact before the bumps, including 33" tires.
This photo is from my TJ...I've replaced the springs and the rig itself lol but same axle, shocks, and bumps.
You are correct about the jounce bumper - it collapses completely into the cup on a hard bump so bumps are checked with the jounces removed.
Reactions: fuse
The shuggs
Edmonton, Alberta
You should remove the jounce bumper, and re-cycle the suspension. While you can measure the distance, and add to the bumpstops, you won't be able to tell if anything else is contacting before full bump.
Blackjack
Kenai
As been said start by taking the bumpstop out of the cup so you do not have to fight compressing it and then jack it up until your spacers hit the cup. Also you can move the brake line mount down the frame to pick up some travel out of it.
Reactions: JMT
Impact LJ
Impact LJ
Tampa, FL
So the only thing not connected is the sway bar, springs, and shocks depending on if you are checking them at the time?
Impact LJ
Impact LJ
Tampa, FL
Good eye on the profile.
So theoretically it should be at least pretty close to the same story for me then eh? Maybe your fenders have something to do with it?
jjvw
Everything is great. No issues.
Colorado, USA
At the end of the day, the shock is the limit to up. The jounce is there to slow the last bit of travel.
Reactions: DylanM345
LONGJP2
Illinois
If you have to limit the travel that much to clear your tires, at what point are the tires not worth it.
However, that seems to be the trend. Really big tires, less travel.
Impact LJ
Impact LJ
Tampa, FL
33" tires with a 4" lift is what is recommended by most people on this site, I can't imagine 35's with this lift.
jjvw
Colorado, USA
It looks like you have the Currie bumps, do they replace the top jounce cup or add onto it?
I'm thinking that's going to be the way to go...
They both replace and add. Without the included spacers, Currie bumps are intended to keep Currie 4" springs from going solid. But they are not intended to stop travel, only slow it. The shocks do the final stopping.
Impact LJ
Impact LJ
Tampa, FL
I thought the shocks weren't to be used as the final stop in order to preserve their life? A body lift might also be a solution.
jjvw
Colorado, USA
I thought the shocks weren't to be used as the final stop in order to preserve their life? ...
I'm guilty of saying that for many years.
The reality is that if you use the right size shock with an appropriate lift height for the desired tire size, then the shocks can be used as the final limit to travel. And you get to use the entire travel of the shock. This means finding a shock that will closely divide it's travel in half from ride height. This gives the shock enough distance (and time) to slow the suspension travel before the shock fully compresses. Extend the bump stops so that the jounces add cushion near the end.
From this, you can infer some of the reasons why a low up travel LCoG build is dumb. The shocks aren't allowed to work properly.
... A body lift might also be a solution.
There are many good reasons to add a small body lift.
Reactions: Rubicon John
Blackjack
Kenai
If you are into the go fast thing this would be some truth to that but for the average recreational wheeler you just want to make sure you are not just crashing into them.
I have never understood that either. Why spend the money to run 14" coilovers and run only four inches of up travel? Makes zero sense to me.
I agree that a 1-1.25 inch body lift is always a good plan.
Rubicon John
Atlanta
Do the LCoG builds emphasize down travel while limiting up travel? In other words, is the shock 2/3+ of the way compressed at ride height?
If so, that would seem to be counterproductive to utilizing the shocks’ full travel.
freedom_in_4low
Monument, CO
The fenders don't add much. They get rid of the flange that the flares mount to but that's like 3/4". 2" bumps were enough to keep 32s out of the stock fenders before I cut them off the TJ, and though I didn't cycle before tearing the LJ apart, I havent found any signs of contact between the 33s and the stock fenders with the 2" of extension it had.
I'll know for sure later in the week, my Currie bumps are supposed to be delivered tomorrow. I was fine with what I had except for this happening when I put on the Currie 4" springs.
I'm admittedly at a loss how you're getting tire contact with 3" of extension and what looks like 2" of air still in between with 33" tires. Where exactly are the tires making contact? And what specifically are you tire and wheel dimensions?
Reactions: LONGJP2
