Front Sway Bar Question
Wajeep
Wa State
Forgive, I don't know much about this stuff. Anyways, front sway bar its slipping to the right (See pic) and it is coming in contact with the frame. I loosened the nuts and adjusted the sway bar back and tightened down the bolts again. It moved again. Suggestion on how to solve my problem? Here are some pics.
mrblaine
Crew Member
Quail Valley, CA
Forgive, I don't know much about this stuff. Anyways, front sway bar its slipping to the right (See pic) and it is coming in contact with the frame. I loosened the nuts and adjusted the sway bar back and tightened down the bolts again. It moved again. Suggestion on how to solve my problem? Here are some pics. View attachment 314955
Same answer as always. Shaft collars on the sway bar on the insides of the mounts.
Wajeep
Wajeep
Wa State
I don't know what you mean entirely. Where can one get these shaft collars? Sorry to sound stupid, but I am still learning here! thanks so much!
Wajeep
Wajeep
Wa State
Do you have an adjustable length track bar up front? A suspension lift with the factory non-adjustable or a misadjusted adjustable track bar will pull the axle to the side and pull the antiswaybar to the side with it.
I believe the track bar is OEM style. I had it replaced about a year ago. If that's the case, what's the fix in your opinion?
Wajeep
Wajeep
Wa State
I think its OEM style. Here are pics.
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
That looks stock so your axle(s) are likely off-center from your 4" suspension lift. Do your tires stick out further on one side? If so the fix is an aftermarket adjustable length track bar(s). Making them longer will push your axle(s) back into the center.
Wajeep
Wajeep
Wa State
About a year ago, I had the jeep aligned and the track bar replaced. Work was done at a reputable alignment/suspension shop. I'm surprised that the mechanic didn't suggest an adjustable length track bar.
Reactions: Jerry Bransford
DrDmoney
WRKP406
The “530”
mrblaine
Crew Member
Quail Valley, CA
Reactions: DrDmoney and pc1p
UhOh
That'll leave a mark!
Marquette, MI
I disconnected my sway bar when I lifted my jeep. Haven't reconnected it since. I don't drive a ton of miles on the road, still, I barely notice any additional roll when cornering. I guess I don't see the point of it unless you're driving mostly on the road...
JMT
The Jeep Guy
I’m not surprised. Many shops are stupid. As @Jerry Bransford asked, is your tire on one side sticking out further than the other? With 4” lift and stock TB I guarantee it is. No use getting the collars. You need an adjustable front TB so you can center the axle under the Jeep. Then it will stop pulling the sway bar to one side.
mrblaine
Crew Member
Quail Valley, CA
Are there any other parts on the rig that assist with chassis control when cornering?
JMT
The Jeep Guy
Very much needed for safety on the road.
mrblaine
Crew Member
Quail Valley, CA
Do a little test for me. Next time you accelerate from a stop with enthusiasm, take note as to how the front end lifts and whether it lifts evenly, or one side tends to lift higher and if so which side.
JMT
The Jeep Guy
We know the driver side lifts more due to rotational engine torque.
