Replacing front Track Bar with Metalcloak but found previous owner had added an extra mounting hole to the axel side bracket. He drilled the inside hole to close to factory and factory hole wallowed out to the point the margin between the holes is too thin/split. How do I fix it? I assume there are welding options to fill 2nd hole, maybe weld washers, and replacement brackets available? If I dont have access to any qualified welders, is there any other way to do it without welding - maybe adding big washers? BTW this is a pure Trail Rig so no DD, trailer it to the trails, only on road is under 45 mph between trail heads etc.
