Yep that's all that matters. If you don't have a torque wrench that particular nut is a three-grunter.What torque did you crank it to?
Thanks no torque wrench here. Think I owe it one more gruntYep that's all that matters. If you don't have a torque wrench that particular nut is a three-grunter.
I think "squooshed " will now be the technically correct term for 40- 50 foot lbs of torque. Let's run with it. It's only life or death on front end parts.
Did you cut off the last nut? Looks like a sawzall made it into the bracket a no
No I did not need to cut it, but I see what your looking at. Who knows.Did you cut off the last nut? Looks like a sawzall made it into the bracket a little.
You got a suggestion for a decent torque wrench that wont break the bank? Harborfreight maybee. I dont know much about them or what size in general I would need.I think "squooshed " will now be the technically correct term for 40- 50 foot lbs of torque. Let's run with it. It's only life or death on front end parts.
Harbor Freight will be fine to get you into the right neighborhood.You got a suggestion for a decent torque wrench that wont break the bank? Harborfreight maybee. I dont know much about them or what size in general I would need.
Man if you do the research they really is a lot of randomness on torque wrenches... If I didn't need one all the time I would just borrow one or run by a shop and get them to torque it.You got a suggestion for a decent torque wrench that wont break the bank? Harborfreight maybee. I dont know much about them or what size in general I would need.
