Installed an Iron Rock Offroad 4" lift kit. Came with a front track bar relocation bracket. Instead with supplied bolts but few this is causing death wobble. Was considering welding the bracket instead of the bolts. Thoughts?
Driver's side, bracket raised up the adjustable track bar. Drag link was adjusted to correct the steering.Which side was relocated and what was done to the drag link to compliment the change to the track bar?
It raised the frame side? That's unusual. If true, you have created bump steer without also raising the drag link at the pitman arm.
FWiW, it is best not to move the track bar mounting locations at all on stock width axles
My apologies, it did not raise the front track bar, the new track bar came with a Heim joint instead of the factor joint. So the bracket is to allow for the new heimIt raised the frame side? That's unusual. If true, you have created bump steer without also raising the drag link at the pitman arm.
X2.... 4" and under you should use the stock trackbar locations and the stock pitman arm to prevent bump steer. I would get an adjustable trackbar and mount it in the stock location.
Hey Jerry,
Long time listener, first time
Commenter. I appreciate all of your knowledge. I’m going to be running OME 2933/2942 springs with Rancho shocks5239/5241.
Would you recommend an adjustable trackbar in the rear or stock track bar with relocation bracket?
