Hi all, I have a 1999 4.0L. So I had issues with long crank time, I pump a fuel pressure gauge on it and I could see that after a couple key primes it would get up to 40 psi and then slowly go down. So assuming that means my fuel pressure regulator is bad. So I went to Oreilly and bought a new fuel pump assembly. It was about 150 bucks.
I went through the whole process of changing it out and everything was great for about a week. Then it started making a high pitch noise one day, constant high pitch noise, then the next day it wouldn't start at all and couldn't get any pressure. Fortunately I saved my old fuel pump assembly. Put it back in and it works ok again, but still has the issue with losing pressure when off.
So my question is, maybe that new pump was just bad? Can I get a better quality one? If so, which would you recommend? I want one that will be reliable and not die in a week out of the blue again. I assume that they don't make the same one anymore? Is it possible to just get the regulator part of it and keep the current assembly? I'm not sure where to find all of these things and would like to avoid Oreilly again.
