Fuel pump replacement
dsher
Reynosa Tamaulipas Mx
Hello guys
the problem with my TJ is it takes multiple times turning the ignition to start
at least 2 after that it works smooth I have no error codes (I don't have a gas pressure test kit so i couldn't check that)
so I've been looking for the bosch correct P/N
and found this one
Bosch 67655 Original Equipment Replacement Electric Fuel Pump​
but it says is for the 19 GAL
today I filled up my tank with 57 Liters about 14 GAL
I had the low fuel light already on before charging gas
so it seems to me I have the 14 GAL tank
does anyone has the correct part number for my TJ? or does it make any diference between 19 and 14?
I have no problem buying another brand but I've read here that bosch make the best oem pump
and I dont want to spend money two times
btw i also found on rock auto this model 69316 but it seems to me i'ts only the electric part and not sure
if it has the anti drainback valve built in (I don't think so)
its a 98 4.0L 6 CYL
any advice will be highly appreciated
Regards from Mexico 🤠
