Fuel tank drop
RHanna
Gallatin, TN
Is it ok the drop the gas tank a couple of inches without disconnecting everything, I would take the filler hose off? I’m tryin to install Antirock rear sway bar and it’s really tight. I have a 1” body lift but I guess the gas tank skid raised the gas tank because there isn’t much clearance and I’m not sure I can get the bar between the tank and body without dropping the tank. I’ll need to cut some for clearance anyway.
You need to drop the tank a few inches to disconnect everything anyway. As long as you don't drop it on the ground while all the hoses are attached, it won't know if you did or didn't finish disconnecting.
