For the first time in two years my TJ wouldn’t take fuel, the pump would run what seem long enough to fill up the filler hose then kick off it took about 15 minutes to get in three gallons. By using an old ford truck trick and pulling the left rear tire up on a 8 inch block and running the pump as slow as possible I got it to take fuel.
Now this is the first time I have needed fuel sense I installed a 1 3/4 inch front leveling kit, could that throw things out of alignment enough that could effect the gravity flow or could it be something totally different?
Has anybody else ran into this and any suggestions as to what can be done about it?
Thanks
Tim C.
Thanks
Tim C.
