Michigan Garage clean out. Pocono Metal, ARB, Mopar, Kicker, blah blah blah
Sea Cot
S.E. MI
Price
1.
Pics available for all items, buyer pays shipping from zip code 48164.
03-06 factory center console subwoofer enclosure with Kicker CompRT 6.75 subwoofer. Speaker hasn't been connected to an amp. Sub enclosure has obvious Gorilla Glue repair job. Factory amp has been gutted with intentions of sealing the heatsink for a block-off plate. $175.
Pocono Metal Craft 6-pc body mount repair kit. New, none of the pieces were fitted or installed. $290
97-98 factory AM/FM cassette player, part no PO4858556AC. Used, works. $20
03-06 factory AM/FM CD player removed from my former 06 LJR. Part number P05091506AF. Don't remember the details of this, can't test it, Bottom panel is quite rusty. Free
Generic draw string winch cover. Approximate seam-to-seam measurements are 21"x4"x8". Free
Tough Stuff Rocker Guard Gasket, open box, never used. two ~4"x84" lengths of textured self-adhesive padding. These go between the armor and paint. $20
ARB leftover parts. Black PA6.6 hose still in factory wrap, also ~4' drop length. Two rocker switch bodies, one front air locker switch plate, one rear air locker switch plate, leftover wiring harness from CKMTA12 compressor- though the dk,grn/blk.pur/yel harness was extracted for SPOD control. I might have fittings and such, too for trail spares $20
LED 3rd brake light on texture coated sheet metal extended bracket. Probably Rugged Ridge, Barricade, or equivalent brand. Wires terminated for factory switch. New, works, never installed, but has some wear and tear from storage. $25
(2) RAM articulating mounts. 3.75"x3.75" square end with ball + ~1.5" round end with ball, + ~5" dog bone with handle. $20 for both
05-06 OPDA housing and Omix-ADA sensor. OPDA was in my former 06 LJR, ran fine when pulled at 161k(?) odometer mileage. No clue if it was original or had been replaced. Replaced due to too much internet-induced paranoia. Unit seems good to go, cheap back up/trail spare item. $25
Reactions: skrelnik and LJGreg
