Gauges, chime and interior light don't work
Francesco.com
Italy
I was mounting the door surrounds using a rubber hammer to place them in position when suddenly the interior light (it’s an additional light that I’ve installed) went out. After that, gauges, chime and light don’t work. I checked the fuse #10 in the glove box, I disassembled the cluster and cleaned the connections and checked the fuse box in the hood. Nothing.
Any idea? Thank you in advance!
In the TJ Resources section there are PDFs of the Factory Service Manual for your year TJ that can be downloaded to assist you in troubleshooting the problem. You can look in section 8W page 15 for the wiring schematics.
https://wranglertjforum.com/threads...ice-manuals-fsm-technical-documentation.4618/
Is there incoming power to PDC fuse #20 that services the Instrument Cluster, Courtesy lights, Dome Lamp and Underhood lamp ?
