I'm in the process of re-gearing my Dana 35 with a Revolution 4.10 ring and pinion set. Right now I'm at 0.007" backlash with the carrier bearing caps on finger tight. The rotating torque of the pinion is 14 inch pounds without a crush sleeve installed. The carrier bearing are pressed on, but the pinion is in place with setup bearing and races. This is basically a convertible for our family, so very limited off road (maybe a gravel or dirt road is about all it will ever see). This is where I'm sitting right now, any advice would be appreciated.
Thanks!
Greg
Thanks!
Greg
