Thank you for your insight! For now I’ll have to continue dealing with poor gas mileage. What other potential problems arise because of a bad combination of tire size to gearsizeGenerally, 1500-1800 depending on what needs replacing. Since you have 3.07 carriers will need swapping which will lean towards the upper end if costs.
Thank you for your insight! For now I’ll have to continue dealing with poor gas mileage. What other potential problems arise because of a bad combination of tire size to gear sizeIt would help for sure.
You might want to check that the previous owner(s) hasn't already regeared it. Does the speedometer read low or high? What highway speed are you traveling that gets 5 mph off?Thank you for your insight! For now I’ll have to continue dealing with poor gas mileage. What other potential problems arise because of a bad combination of tire size to gearsize
Reads 60 but going 65. Unfortunately.You might want to check that the previous owner(s) hasn't already regeared it. Does the speedometer read low or high? What highway speed are you traveling that gets 5 mph off?
If the speedometer reads 50 when you're really doing 55 for example you probably have stock gears. If it's reading 60 then it may be regeared already
Then yeah I suspect you have stock gearsReads 60 but going 65. Unfortunately.
There should be a tag on the diff cover/s that will have the ratio imprinted. Something like, 3.07, 3.73, etc is what you'll be looking for. The 3spd auto with 33's and 3.73 should actually be very usable. If it is performing poorly it is very likely you have 3.07.Reads 60 but going 65. Unfortunately.
First with what you have how does it perform in 4LO on a gravel road. For me this was why I never regeared. It ran like a Mustang in 4LO and would hit 60mph.
obviously we have different goals. Me I like speed. I grew up with go karts... the 100mph kind, and rally cars. I have zero interest in crawling up a waterfall. When the the highway sign says, slow to 60kph for a curve,,,,, even in my TJR I take that corner at 60mph.... even with a trailer. Different goals, different needs, different results.Why is this a virtue?
You guys are so frickin' close minded. You treat different opinions as personal attacks.
Great looking Jeep! Looks super clean. Congrats! Time now just to love Jeep life. With summer around, top down and doors off, nothing like it.Yes I went into this without the knowledge I should have had had. The tires were already on and fairly new. It’s a daily driver so has mileage is less than ideal. I’m not sure of what inch lift. Total girl here but trying to learn. I am ashamed to say I don’t do off road but I love my Jeep! How can I measure the lift properly? Here is a pic to give an idea. View attachment 96784View attachment 96785View attachment 96785
Like I said, open yer mind. You just proved my point.That isn't what is happening. What is happening is that your gear recommendations don't make sense. They never have. And they never will.
None really, the on and off-road experience is simply lackluster. Honestly, the $1000 I spent to have mine regeared is the best money I’ve spent on my Jeep (I already had the right carriers). I have power, not saying it’s fast or something, but it gets up and goes and I have reserve power at 60-75mph so I can pass. Zipping around town is a ball.What other potential problems arise because of a bad combination of tire size to gear size
Well. You can be the spokesman for those who want to hit the highway in 4 low. I'll admit that I just don't get it. Maybe I'm missing something. Do the Baja guys shift into low range when they are looking for that kind of speed?Like I said, open yer mind. You just proved my point.
you really need to put the attack dog awayWell. You can be the spokesman for those who want to hit the highway in 4 low. I'll admit that I just don't get it. Maybe I'm missing something. Do the Baja guys shift into low range when they are looking for that kind of speed?
The big one, if you are way too high, ie 3.07s, 33s, automatic or clutch, you might not have enough lift from a stop and damage the torque converter or shorten the clutch life. I had no problems with a clutch, not so sure about an automatic tho.What other potential problems arise because of a bad combination of tire size to gearsize
Thanks for qualifying that.Well. You can be the spokesman for those who want to hit the highway in 4 low. I'll admit that I just don't get it. Maybe I'm missing something. Do the Baja guys shift into low range when they are looking for that kind of speed?
