Yes, stay in 2H on paved and concrete surfaces.Is driving in 2Hi recommended on the highway? Again, showing my lacking knowledge here.
For 4H and 4L you need a surface that allows the tire to slip (e. g. Snow, gravel, grass, dirt)
Oh I’m in a 3 speed automatic.Yes, stay in 2H on paved and concrete surfaces.
And without changing out the 3.07 to something more appropriate, there is really nothing that can be done to make speedometer correct?There should be a tag on the diff cover/s that will have the ratio imprinted. Something like, 3.07, 3.73, etc is what you'll be looking for. The 3spd auto with 33's and 3.73 should actually be very usable. If it is performing poorly it is very likely you have 3.07.
2Hi, 4 Hi, and 4 Low refer to the transfer case, not the transmission.Oh I’m in a 3 speed automatic.
Thank you. The only issue is the charts don’t cover my combo. 33s and 3.07 gear ratio. So I’m unsure of which speedometer gear to get.Yes, the speedometer can be corrected two ways depending upon your particular transfer case. The first method is to change the plastic speedometer gear and the other is with an electronic device that alters the signal to the vehicle computer.
https://wranglertjforum.com/threads/speedometer-calibration.6098/
https://wranglertjforum.com/threads...ometer-after-changing-tire-sizes-or-gears.83/
https://www.google.com/search?q=how.....69i57j33.17643j0j7&sourceid=chrome&ie=UTF-8
If you haven’t used part time 4 wheel drive before, I’d recommend taking it to a gravel or dirt parking lot and shifting through all four transfer case positions just to get a feel for how it works and what they do. (Don’t do it on dry pavement though)Ahhhh. Thanks!!
Will do! ThanksIf you haven’t used part time 4 wheel drive before, I’d recommend taking it to a gravel or dirt parking lot and shifting through all four transfer case positions just to get a feel for how it works and what they do. (Don’t do it on dry pavement though)
The chart I attached link for is blank for the 33" tire/3.07 gear ratio, does that mean I would be unable to change the speedometer gear?Yes, the speedometer can be corrected two ways depending upon your particular transfer case. The first method is to change the plastic speedometer gear and the other is with an electronic device that alters the signal to the vehicle computer.
If you use a digital correction device, it doesn't matter what speedo gears are out there. They solve all the ratio tire size issues. We use them a fair bit with Atlas installs since the big tires and low gears require a gear that is too big to install while it is attached to the sender. You have to drop the gear in, tip it behind the drive gear and then stab the sender onto the shaft and pray that it stays snapped in. Easier and better to grab any smaller gear and then correct it digitally.Someone else may know if there is a "25" speedo gear, which is what the chart suggests would be appropriate for 33's and 3.07 gears, but unfortunately I do not.
If there isn't a "25," you could use the "26" gear specified for 3.07 gears and 32" tires and see how close that gets you (many tires listed as 33" in diameter are actually 32.8" or sometimes slightly less).
Is this something that I can do myself? Do I install a smaller gear and then do this digital correction? I'm sorry if your explanation covered this and I'm jut not getting it.If you use a digital correction device, it doesn't matter what speedo gears are out there. They solve all the ratio tire size issues. We use them a fair bit with Atlas installs since the big tires and low gears require a gear that is too big to install while it is attached to the sender. You have to drop the gear in, tip it behind the drive gear and then stab the sender onto the shaft and pray that it stays snapped in. Easier and better to grab any smaller gear and then correct it digitally.
You don't have to change the gear if you use the digital correction device.Is this something that I can do myself? Do I install a smaller gear and then do this digital correction? I'm sorry if your explanation covered this and I'm jut not getting it.
I despise the shit from a blue monkey.I would have suggested that because I have a Speedohealer electronic correction device myself and it couldn't be simpler to install and calibrate, but I assumed OP was looking for a lower cost option.
http://www.bluemonkeymotorsports.com/products_ht.html
So I read a few posts and people used the 26 for this combo and it worked. How do I determine whether I need a long or short shaft? I know its based on whether the speedometer is electronic or cable driven but how do I know the answer to this? Sorry for my general lack of knowledge here...Someone else may know if there is a "25" speedo gear, which is what the chart suggests would be appropriate for 33's and 3.07 gears, but unfortunately I do not.
So the front coil is 14.5” and the rear is 10.5” so both have a 2.5” lift, correct?Great looking Jeep! Looks super clean. Congrats! Time now just to love Jeep life. With summer around, top down and doors off, nothing like it.
Good gas mileage will never be a TJ’s strong suit. It is what it is. Learn to punch penny’s and save for the next sheep mod, or gas!
To measure your true lift, look behind one of your front tires and find the big coil spring. You want to measure that spring. If there is a plastic spacer sitting on top of the spring, include that in the measurement. Don’t include the rubber coil spring isolator at the very top. Stock length is 12”, so anything above that is the amount of lift you have (e.g. 15” would mean you have 3” up front). Do the same in the rear, but stock is 8” and so anything over that is your lift in the rear.
Then report back. This will help determine what is the best tire size for your lift.
Then we can think about re-gearing for that tire size.
But for now just enjoy your new Jeep. There’s nothing else like it!
