If shifting problems occur only when the vehicle has been running for a while, is it possible to eliminate mechanical issues (ie, focus on fluids and leaks)?
I have a similar issue, just switched the fluid over to MT-90 and it did help some but not completely. I believe it’s my clutch master/slave assembly. Do you have any clutch chatter with the pedal depressed and the trans in 1st gear?
Maybe pull the slave cylinder while things are up to temp and acting up? Have someone depress the clutch pedal while you watch the piston of the slave cylinder.
