What shifter part number did you go with? I don’t see one for the Jeep transmission
Not sure about a Jeep one. I run a 4l70e
What levers did you for the atlas to come up centered?Finally finished mine. View attachment 137649View attachment 137650
AA part# 303009. That's what the console is designed for.What levers did you for the atlas to come up centered?
Well that makes it easy! I this nag1 swap works I'd like to make that switch to the GR consoleAA part# 303009. That's what the console is designed for.
Having looked into the electronic brake it's not rocket surgery but it is more complicated than a lever.I'm going to have to cut an extra hole in my console for the STaK's shifters since I have 3 levers. I'm still not sure what I am doing with the parking break yet.
Awesome, thanksThe TF999 is close to the 42RLE so it should work from what I understand. I have a 46RE trans and bought the kit for the TF727 and will have to make some custom brackets to mount the shifter cable.
Wow, that is nice! I may have to look into that.I’m not sure they would sell them in mass, but the Wide Open Design aluminum center console is beautiful. It’s a lot cleaner than the Genright with the clean radius bends in it compared to the Genright’s 90° corners.
View attachment 232248View attachment 232249View attachment 232250
Do you happen to have any pics of the inside of the console and how the shifter cables are run?Finally finished mine. View attachment 137649View attachment 137650
Didn't get this notification until now sorry about that. I don't have any pics, but there is no instruction on how to do cables. I had to mount and unmount many times to find a place they would all live and work right.Do you happen to have any pics of the inside of the console and how the shifter cables are run?
Have you seen any more pictures of this? I'm curious where the TC shifters are positioned.I’m not sure they would sell them in mass, but the Wide Open Design aluminum center console is beautiful. It’s a lot cleaner than the Genright with the clean radius bends in it compared to the Genright’s 90° corners.
Driver drop case and driver drop front casting. The shifters for the transfer case are to the right of the driver’s right knee as viewed when seated.Have you seen any more pictures of this? I'm curious where the TC shifters are positioned.
Wow. Somebody there is unbelievably skilled at body work. So much to see in those pictures!Driver drop case and driver drop front casting. The shifters for the transfer case are to the right of the driver’s right knee as viewed when seated.
There are no good shots that give full context. But here are two:View attachment 249915View attachment 249916
Same WOD JC chassis but different builds that utilize driver side drops axles and transfer cases:
View attachment 249917View attachment 249918View attachment 249919View attachment 249920
It’s excatly why I created this thread to archive some high res shots of their work over at WOD.Wow. Somebody there is unbelievably skilled at body work. So much to see in those pictures!
I found this thread while looking for center console idea/products as I'm about to do an LS/6L80 swap. Great info for that that has my mind spinning on options. While eyeballing everything I couldn't help notice that dash (which others have commented on). I'll likely need to do some sort of custom dash, and I really like the idea of something configurable. Is this what you are using?It’s excatly why I created this thread to archive some high res shots of their work over at WOD.
It’s inspirational and motivational for me and I hope it does the same for other members here. Even though it’s not in the same league as our builds here, some of their work can still be drawn from IMO.
Wide Open Design's TJ and LJ Tube Chassis
Wide Open Design has been in the Jeep scene for a while. I grew up watching WOD Jeeps crawl all over GreyRock ORV, Morris Mountain ORV, and other trails throughout Alabama. There is no doubt that their work is some of the best in the off road industry. WOD revolutionized the GM 14 bolt front...wranglertjforum.com
